I want to select some bullets with color and then clear the color. I cound’t find a way.
I know I can search for color but then even selecting all I can’t apply the clear color. And how to select only some bullets not in order?
You can use the Ctrl+Shift+Backtick
shortcut or click on the applied color again in the menu.
Hi Erica, I mean bulk clear color and only for the selected bullets.
Yes, drag to select them all and then use the shortcut or the menu option. Is that not working?
I’ve filtered color:yellow in search, selected all, did the shit+control+ ` and it didn’t cleared the color.
Still I was looking for a way to clear selected skipped bullets (not together) without using the search.
