I take a shortcut to another document or zoom out to the whole document.
To see the items in that section.
Sometimes the screen is blank. Othertimes, the items are the same as where I was coming from, except the heading of the new position I had navigated to.
Windows 10, Chrome 61.0.3163.79
This problem can usually be solved with a tab refresh, though it adds an element of confusion to the workflow.
