Yesterday (20 September) print width suddenly changed from full width A4 to narrow, see image. Maybe it was a setting after I changed a font. Any suggestions?
Thank you
Thank you
Had another go at finding the problem.
Shortcuts & Formatting in the main menu toggles narrow and normal print display.
Is this is a feature or a bug?
Solved!
Sounds like a bug. Will make sure that’s no longer the case, thanks for finding the bug!
For info, narrow print happens when the Shortcuts & Formatting menu is open in Windows 10, Chrome.
Confirmed the bug, will fix!
