OAuth failure with signing in on iOS
The problem occurs when creating a shortcut on the home screen from within Safari. When I run the shortcut, I get redirected to the login-page. Here I try to Sign in with Google. Having clicked that button, I get redirected to a 403 error page:
Error: disallwoed___useragent
This user-agent is not permitted to make an OAuth authorization request to Google as it is classified as an embedded user-agent (also known as a web-view). Per our policy, only browsers are permitted to make authorization requests Google. […]
Sounds like it prohibited and I’m not even sure if it has to count as a bug. However, it does render the home button shortcut useless since I’m registered on Dynalist via the Google OAuth function.
Is there a workaround?
@Shida & @Erica
Does the shortcut still redirects to the login page when you have already logged in on Safari?
Yes, it does. And if I’m clicking on login on the top right of the page, then dynalist switches ā€˜programs’ and opens up in Safari. Here I can log-in as usual or am already logged in.
Google doesn’t want to talk to the widget. :information_desk_person:
Huh, so the widget is running in its own thing, isolated from Safari’s context… I guess in that case there’s not much we can do.
The oauth error page is something Google specifically implemented - They disallows logging in through webviews specifically because it’s a pain to login again, and recommend the ā€œopen a login page in your browserā€ method. We implemented that in our mobile apps, but we didn’t expect needing that on the web version.
I would recommend you to chat with @Erica to get the iOS beta app instead.
Yes, once the iOS app is out, the problem should go away, unless you have to use it in a widget. The home screen app should be deprecated after that.
Alright then, thanks for your answers. I’d be interested in the beta app, though @Erica; how would we do that?
Sorry about the late reply, the closed beta is currently closed, but the good news is the app is close to a release! iOS app in review
