similar to this: Bolding multiple lines changes some of the other lines
multiple lines suddenly appearing bold
select all bold lines, press cmd-B to try and bulk-remove bolding
seems to work, but some lines contains multiple on either side
remove formatting by keying cmd-B repeatedly
cursor other lines
return to original line, asterisks have reappeared
formatting remains removed
multiple instances of asterisks, which can be removed by select-delete, or pressing cmd-B repeatedly, which removes one asterisk from each end of the line with each press.
Which operating system are you using? MacOS 10.12.3
Which browser are you using? Safari
If youāre using a desktop or mobile app, whatās the version number of Dynalist? 1.0.1
Iāve deleted all the spurious asterisks for now, will report if they reappear
