Links copied via iOS share sheet cannot be pasted to Dynalist
  1. Navigate to a website in Safari or Chrome
  2. Tap the share button
  3. Tap copy
  4. Open Dynalist
  5. Create a new list item
  6. Tap the blank space of the list item, then tap paste
  • Copied link is pasted
  • List item remains empty; copied content is deleted from clipboard (was able to paste to other apps directly, but after the failed attempt to paste to Dynalist the content could not be pasted elsewhere)
  • iOS 11.3.1
  • iPhone 8
  • Safari and Chrome
  • Dynalist 1.2.6
This has a huge impact on whether I stick with Dynalist and go Pro or if I go back to Workflowy or something else because it’s a big part of my daily workflow. Thank you!
This is happening to me too.
When copying the top URL section, I can paste.
When copying via the share button, I cannot paste.
