Item counts for Search-based Bookmarks
For a search-based bookmark, such as a GTD tag like “@next”, I would like to see “@next (X)” in the bookmark pane where X is the item count of my search results for that tag. Just like you have in the Tags view, but for bookmarks pane view as well… Of course, if they are completed/checked off then I do not want them in my count result. Thanks, Erica! Happy to be a paying subscriber!
Thanks for the suggestion, David!
Unfortunately this would be a bit tricky, since the bookmarks need to be loaded from time to time for the counter to update dynamically.
I’m guessing tag pane counter can’t replace your bookmark setup?
