We have 2 documents: “doc A” and “doc B”. We want to create copy of “doc B” by the name “doc C”.
- Have “doc A” selected in document list.
- Right-click on “doc B” and do “Make a copy”. System makes a copy and prompts to enter name of the copied document.
- Type “doc C” and press Enter.
4.1. If you wait for couple of secs, “doc C” will revert to “doc B” for some reason.
4.2. Alternatively if you quickly select “doc C” - you will see that the header of the opened document is “doc B” and name of the “doc C” document in the document list reverts to “doc B” shortly.
Step 1 is somewhat important since you can reproduce the problem in 100% of cases. If you left-click on “doc B” before right-clicking, problem reproduce from time to time only.
I would expect a copy to be created and it’s name not reverting to the original .
If you wait for couple of secs after Step 3, “doc C” will revert to “doc B” for some reason.
Alternatively if you quickly select “doc C” after Step 3 - you will see that the header of the opened document is “doc B” and name of the “doc C” document reverts to “doc B” shortly.
OS: Windows 7.
Application type: installed desktop application v1.1.7.
