Edge Browser - Copy and paste - pastes "Dynalist"
fixed
General copy and paste of any text in a dynalist document
I expect what I copied to be pasted
I don’t get the copied text, rather I get the text “Dynalist” pasted into my document.
Edge
Windows 10
Sorry for the late reply, I can repro this bug on latest Edge and definitely will fix!
No problem. thank you! Erica, do you ever sleep? :slight_smile: Thank you for being such a hard worker.
Hehe that’s a funny joke!
But in case you’re actually wondering… we make sure to get plenty of sleep to better work on Dynalist. :slight_smile:
Btw is Edge the only browser you can use in your environment? That would help us determine the priority of this bug.
Erica,
Thanks for asking. Yes its a corporate environment and edge is the standard, so I can’t use other browsers.
Warm regards,
Chris
Got it, thanks!
#7
@Chris_Kunicki: This should be fixed in the latest versions (please refresh/reload the app to update), could you please confirm when you have time? Thanks in advance!
Sorry for the late reply!
#8
Dear Erica,
Thank you for the update and I am happy to report this is working. Thank you for addressing it. It was helpful to know it was on the todo list. So thanks for getting to it.
Warm regards,
Chris
#9
Hi Chris,
Thanks a lot for confirming! :heart:
