Duplicating items on MacOS
I’ve tried duplicating using Cmd-Drag, but that doesn’t seem to work for me.
MacOS/Safari
Any tips?
If that doesn’t work, then collapsing and highlighting the entire line (and not just the text on the line), then copying and pasting it on a seperate line should work.
Could you please try Ctrl-Drag instead? @Nick_Davitashvili
Hi @Erica,
I’ve tried that one.
Ctrl is an equivalent of Right-Click on Macs, so it just brings up a context menu when Ctrl-Clicking an item. An easy fix would be to add the Duplicate option to the menu.
Uhh, I didn’t know that.
Well, in that case I guess the workaround is to select the item (Cmd-A or Cmd-A twice if you want to copy the children) and then use Cmd-C and Cmd-V to copy paste. And yeah, a menu option to duplicate with a shortcut would be nice.
