Date picker cut off at edge of narrow window
  1. Shrink window so that the right side of the document is up against the window border.
  2. Use “!” at the end of a long line.
Calendar is shifted in such a way that it is fully displayed.
Calendar is cut off by the right side of the screen.
Windows 10: In web app (Chrome version 60.0.3112.90) and desktop app (Dynalist 1.0.37).
As the date picker gets closer to the end of the screen, it shrink to accommodate, but at calendar widths less than about 180 pixels it gets cut off.
I use a multi-monitor setup, but my non-primary monitors have resolutions of 1024 x 768. Often I’ll have my notes on these, where I’ve sometimes run into this problem.
Thanks for the bug report!
Is it possible to attach a screenshot? (Simply drag and drop or paste)
Sure!
Thanks! We’ll look into this bug and fix it as soon as we can :slight_smile:
I’d like to add my voice to this issue: date picker falls off the edge of the monitor and is not fully displayed, if date is being inserted near monitor edge.
This should be fixed in the latest versions (please refresh/reload the app to update), could you please confirm when you have time? Thanks in advance!
Tried in Firefox (66.0.3 64-bit) and desktop app, calendar is shifted over correctly in both cases.
Thanks a lot for confirming!
