Does anyone know if there is a way to change the bullet color when applying a color label? I have a Stylish code installed to add a color bar to the left of the text instead of the highlight, but wondering if anyone tried changing the bullet color instead and if it would actually look better.
No, there is no way to do it with Stylish, CSS is not flexible enough. You can only change this color bar to be a bullet and move it to the left so it can cover original bullet. In that case you can’t click directly on the bullet to expand/collapse, but there is some area outside of bullets which can be clicked to do that.
Got it. Thank you for confirming, @Piotr . I’m glad to have a definitive answer so I can spend time elsewhere.
