In Dynalist pro settings, bulk enable calendar syncing for all documents.
Settings correctly shows that 2 documents are sync enabled.
Wait a day or two.
I expected all documents to stay sync enabled.
At some point the number of syncâd documents resets to zero and no reminders appear in google calendar.
Web version Chrome, Mac,
