Autocompletion in checklists
Hello!
Google Keep (I have not seen this from anyone else) has the very convenient and nice feature: auto-completion in checklists. For example: I have a grocery list of about 50 items (accumulated in a few different trips to shops), and I don’t want to search “Bread” in the list for unchecking, I just want to enter “Bre” and see completed “Bread” in the drop-down menu, then click/touch on it and it moves to the place where I typed and becomes unchecked.
There is custom hand-made example how it may looks in Dynalist:
I hope, I have clearly stated. Anyway, you should try this in Google Keep.
Thank you!
Thanks for the suggestion, I can certainly see how this can be useful to you!
I installed Google Keep but have no idea how to trigger. Long holding the checkbox doesn’t seem to do it. How do I trigger this feature?
It works by type start part of checked items in this list.
But they changed something: added somewhat of global dictionary completions (with cart icon).
So sorry for the late reply!
Unfortunately, after some internal discussion, we feel like this feature is too todo-centric. It’s also weirder when I imagine it on Dynalist because in Dynalist your tasks do not get automatically reordered after completing a task.
To others: please do comment below if you feel like you need this too! Thanks in advance.
