Won't scroll when dragging items
Nice app, but I can’t use it because you can’t move items up any higher than the first line that appears on the top of your screen. I have several very long outlines, and it’s impossible on your app or on the mobile web page to drag an item to the top of the list. With WorkFlowy, for example, you can move your finger above the top of the screen and the list will continue to scroll up to the place where you want to drop an item. This is the scrolling mechanism for most word processing and database apps as well. Not so with Dynalist. I know I can hit the up arrow to move an item, but I would have to do it 30-40 times, and it’s slow.
Thanks-
Thanks Allen! I received your in-app feedback as well.
Since you’ve already filed it as a bug, do you mind if I remove the other topic in the “Help” section? @Allen_Michie
Just so long as I get an answer somewhere from somebody. Thanks.
Hi @Allen_Michie1, sorry for digging this up :grimacing:! We’re cleaning up the bugs and would like to know if the bug is still happening to you? If not we’ll close this bug :slight_smile:
