When you convert it to pdf there is no vertical line which you can see when editing.
however, vertical lines can be a visual helper
you can see exactly which bullet points are under which bullet point.
you can see which level the bullet points exist.
You can clearly see the difference when you convert PDF on workflowy. See the img.
