Unindent on a Chromebook deletes the entry
Shift + tab deletes all the text in a single bullet point.
The text unindented.
The text deleted, with the line underneath moved up in its place.
Chromebook. Chrome OS Version 55.0.2883.105 (64-bit)
I think it just got moved to below all its children, as the next sibling of its parent.
Can you check and see if that’s the case?
Egads! I just noticed this and was trying to delete my post.
Geez, you’re fast!
I’m sorry about my error! I had a long list, and I kept “losing” some info.
Thank you! Feel free to delete this.
