The main panel does not scale horizontally beyond
resize browser window to full screen; the document node (see below) stays around 900px width max
body > div.page.mod-app.AppContainer.is-borderShowing.is-highlighting-overdue > div.main-container > div.normal-view > div.DocumentContainer.is-largeFont.is-comfortableDensity.has-tagBackground.is-centerDocument > div.Document > div.Document-rootNode.u-use-pref-font
Document node should resize accordingly to browser window size, without width restriction up to full screen width
Document node gets to a certain width, and does not expand any more, regardless of browser window width
Windows 7 & Chrome
Thanks for reporting this!
Since you’re already using the developer tools, are you referring to the 60px padding at both sides?
Thanks Erica and please mark as Solved. I’ll paste your response here for documentation/posterity sake:
“(…) you should disable the “Center align document” option in Settings - Preferences - Appearance.(…)”
