Target popup for internal links
Just like the popup that appears when hovering over a tag (e.g. the tag #MyTag shows Filter #MyTag), I would find it useful to see a popup with the target breadcrumb when you hover over an internal link (e.g. the link Todo would show Folder \ Projects > Important Project > Todo or Goto Folder \ Projects > Important Project > Todo).
That would be very useful, especially if you have for example multiple Projects (each with its own Todo item), you could just by hovering over the link see where it leads to, without actually going there!
