Using the Share to Dynalist within other apps on an Android phone (such as saving a webpage etc) saves to the Dynalist app but does not sync correctly unless you copy and paste the item into a new line.
That the sync correctly works by syncing the items I have chosen to the main webpage/Windows application.
Having to copy and paste the item again and then it syncs.
OS Windows/Vivaldi Browser for main usage, Android phone with Dynalist app ver 1.3.3
