Swiping from left while in options menu opens Dynalist sidebar
  1. Open Settings on mobile.
  2. Swipe from the left
Nothing occurs OR options menu dissapears and Dynalist sidebar slides out
Dynalist sidebar slides out underneath the settings window.
Android, Google Chrome
Just a minor UX oversight I wanted to point out on the mobile web app.
Whoops!
Confirmed, will fix, thanks for the nice catch @Dynalist_User! (Nice name btw.)
Should be fixed now, on the web app at least. Coming to other platforms soon!
