Sub-items not moved when dragging item to document pane
  • In document with item and sub-items.
  • Drag item with sub-items to document pane to create new document from dragged item.
All sub-items part of dragged item moved into new document.
Document created with dragged item but missing all sub-items.
Dynalist web version
Google Chrome 60.0.3112.101
Windows 10 Version 1703 (OS Build 15063.540)
Additional observations
  • Go back to original document and press Ctrl-Z for undo to get moved items back. Sync.
  • Open the previous document again that had sub-items missing.
  • Observe that sub-items that should have been moved when creating document is now visible, as if the item is mirrored between two different documents at once.
Hey @void,
It seems this bug happened during our semi-downtime on August 28, so it could be caused by the unreliable sync back then, which is completely gone now.
Can you reproduce the same issue now?
Hi @Erica,
You are right, I’m not able to reproduce anymore. Thanks!
Thank you very much for confirming!
