Create a Node
Add a Note with more then 2 lines
Create a second node
Crop note from node 1 and paste it in the note section of node 2 (structure is not copied over)
Copy note from node 1 and paste it in section of node 2(structure is copied over)
Cropping content also copies the structure over
Structure of note was not copied
MacOS, Chrome
