Enable spellchecker
Select a word underlined red
Pop-up window with spelling suggestions etc
Pop-up window appears blank, but responds when clicked with a correction or deletion of word.
Android 10, also same result Android 7
Which browser are you using?
Chrome
If youâre using a desktop or mobile app, whatâs the version number of Dynalist?
Android v1.4.15
n/a
Same result with different virtual keyboards: Gboard, AOSP, Hackerâs keyboard
!Additional comments
I reckon the spellchecker suggestions do in fact load into the pop-up window but that the text is rendered transparent.
