Settings window too small
No matter my zoom I can’t see much!
Can you paste a screenshot of this for us?
I should note that the size isn’t small enough to bar functionality. I’m using the phrase ‘too small’ subjectively.
I see. How would you suggest improving it? Would it be ok if it filled up the entire tab?
Just making it larger, yes (especially on large screens!).
@Erica is there a way to have the settings menu scale in proportion to Dynalist? I think that might help temporarily, before an overhaul, if needed.
I think it does scale with the browser window right now… if I understood your question correctly. See the screen recording above. Is that what you mean?
Ah, I see. So I guess have a set value for the proportion of it to the rest of the screen/tab’s space would help instead?
