Settings menu still locked on tablet on mobile site
Open the Settings Pane on the mobile site (or the android app) from a tablet.
Ability to see ALL settins
Can only see whatever fits on screen. Pane is not scrollable.
Chrome on Android 6.0 (happens on the standard browser also and the app)
I think this is a duplicate report of this bug. It’s been a while and we really should fix this… bumped up in our priority queue!
Ah, a two month old bug.
Mobile gets no love. :expressionless:
We did investigate the bug back then, but no luck. The bug only happens on the tablet but not the phone, both for Android and iOS, which is unusual.
We’ll take a look at it again, but it’s not always straight-forward to fix bugs, putting in hours doesn’t guarantee any progress on a bug, unlike most other work. Rather than getting stuck on a bug and do nothing without first resolving it, we thought the most logical action is to resume working on other things to make some progress. I know it’s strange to people who’ve never done development, hopefully it makes sense.
It makes me think that we should post failed attempts to fix bugs in the future, so that it’s transparent that we’ve put in the effort to investigate the problem but failed to make progress. Plus there are a bunch of users who are also developers themselves; they can probably help a bit seeing how and why we failed to pinpoint the bug.
I like this idea. Transparency does make people (or at least people like me) happier, because then no one can point fingers and feel like they’ve been ignored. (Not referring to my experience with Dynalist, but other products.)
Update: this should be fixed now upon refresh. Apps will receive this fix soon.
Thanks, that seemed to fix the white space scrolling bug that was happening too.
That’s something different but yeah they were fixed in the same release.
