Send item in focus mode
I would like to send an item using the “Ctrl+Shift+M” Method in the title bar also. That is, even if it is focused in an item, it can be sent away and focus in the original parent of it.
Will it be a good suggestion?
What’s the the use case behind this?
It could be confusing since some people would like to continue working in the current focused item rather than being sent to the parent.
I am open to both options.
My original idea was that sending the item away without leaving the original document is what “send item” meant to be.
But it makes perfect sense to work in the same focus after sending the item to another place.
