Unable to select item, need to click on the item and click esc to make the selection work.
When I select an item, I drag the mouse without pressing the button, and it acts as if I am pressing the button (highlighting items by moving the mouse).
The selection behaves normally.
See steps to reproduce section.
Windows 10
Which browser are you using?
Chrome, Edge and Internet Explorer
Chrome desktop version 92.0.4515.107 (Official Build) (64-bit), didnāt check other browsers.
Negative.
It started this week, and only on my work computer, and I tried clearing the browsing data and restarting the computer, but it didnāt fix the problem. I donāt have this problem with any other site.
