Right click menu drag
Right click item in folder or bookmark pane
Open context menu and item stays in place
The item moves with the cursor in the context menu
Chrome Version 58.0.3029.110 (64-bit)
The problem does not occur in Firefox.
I mentioned this a couple of months back, but it has persisted and I can lose data as a result. So I thought a screen capture might be good to clearly identify the problem.
I forgot how I replied a couple of months back, but I can’t reproduce this problem right now. Right clicking behaves normally, and even if I drag the document/folder while holding right click, I don’t see what’s in the screen capture.
If holding the mouse is not required, I think this bug is really easy to catch and we’d receive lots of reports. Maybe there’s some Chrome extension intervening?
Thanks for that feedback, @Erica. I tested different Chrome extensions and found that the culprit was Linkclump, which I am happy to do without. :relaxed:
GREAT to hear! :slight_smile:
