Pull items into a document
It is really a good design to pull item into the file pane to create a document, but I think it will be even nicer if I can pull some items INTO a document to move the items into it (like move item into it).
Are you asking to be able to drag items from an open document into an existing document in the file pane?
Yes. Thanks for clarification.
