Before my litany of complaints here, first let me start off by thanking you for creating an amazing product. This is (to use a current expression) the “Superhuman of outliners”!
Today I just lost a bunch of time trying to figure out how to set an item as my inbox. Turns out it’s because I can only do it from your desktop electron app, but I can’t do it from a web browser, nor can I do it from your iOS app (that I use on my iPad Pro). I think features should be identified in the docs as being supported on Website, iOS App, Desktop App (are there other categories?)
Tangentially related to parity across experiences, I would also love it if you could give some love to your iOS app. There are a ton of bugs in the app that I can report separately if it helps (do you have a bug tracker, or is the forum the best place?). I like to use my LTE-equipped iPad Pro as a mobile computer, but your iOS app with the physical keyboard is borderline unusable. It might be OK to capture random ideas into an Inbox, but any real work needs to be done on a laptop / desktop.
Thanks for creating a great product. Looking forward to mastering its many, many features. Thx!
