Copy some text (anything). Select an item (Ctrl-A, Ctrl-A) so that the blue highlight bar extends around the entire item, not just the contents. Paste (Ctrl-V).
The content should be pasted into the item but the screen shouldnât scroll.
The content pasted correctly, but the screen jarringly scrolls upwards.
See this screen capture: https://streamable.com/zuucj
Initially it shows what happens when you only highlight the contents and paste, and it doesnât scroll. Then it shows what happens when you highlight the whole item and paste, and it does scroll.
Chrome/Windows 10.
