Parent hierarchy not associated with text
Copied + paste a whole bulletpoint of information (CTRL+A, CTRL+A , CTRL+V) to a designated location
Tried adding a new bulletpoint:
On windows PC / chrome
You can see the parent text getting seperated from the bulletpoint hierarchy, and its header tags / colors
I think you have an invisible character at the end of the first time, and it got split to the second item.
Can you paste what’s in your clipboard here so we can take a look at what characters it contains?
whoops i put all personal information there too
it had lots of sub bulletpoint information under it
In any case, what I mean is that there’s an invisible character after the last word (“again”). If you remove the word “again” and everything after it, the problem should go away. You can definitely tell when there’s an invisible character, since when you hit Backspace at a certain position, the cursor won’t move.
okay thanks erica :slight_smile:
You’re the most welcome! Let me know if you’re still having issues with this.
