One very large document I in Dynalist made will no longer load. When I click on the document on the file pane, it gets stuck at the loading ‘infinity’ symbol, and I am unable to click anything else in the browser. The document is shared. No extensions are enabled. Using fully updated Chrome. All other documents on my Dynalist work normally…
Have you tried another browser?
Yes, Mozilla, IE.
A possible workaround could be to recreating it from a backup. Hope that helps.
You also might try Exporting the document from the file pane to save it to disk. From there you could try re-importing it or maybe breaking it into smaller pieces.
Sorry for the late reply!
Could you PM or email me (support@dynalist.io) the name of the large document please, @Taylor1?
