- Turn on offline mode
- Turn on sharing for a document
- Turn off sharing for a document
- Document is gone
- No option to share a document when in offline mode
Or - Turn on sharing for a document
- Document is still available
- Document is gone
Which operating system are you using? MacOS
Which browser are you using? Electron app?
If youāre using a desktop or mobile app, whatās the version number of Dynalist? Donāt know where to find this.
Are you using any third-party scripts for Dynalist, e.g. PowerPack? Nope.
