Not being able to paste anything
Copying something and pasting it is not working
Its pasting an image constantly which does not exist
Which browser are you using?
Sounds like your operating system has a stuck clipboard. Have you tried pasting into other apps to see if the issue keeps happening everywhere? Reboot?
If you don’t specify OS, not much can be said.
