"Move to..." shortcut not working
Pressing Ctrl+Shift+M in the Windows app
Move to… popup should appear as with the context menu
Nothing happens
Which operating system are you using? Win10 64bit
Which browser are you using? none, its the app
If you’re using a desktop or mobile app, what’s the version number of Dynalist? 1.3.5.
Can’t seem to repro – any chance you’ve customize the hotkey somehow? Or is it possible that you recently installed software the could have intercepted Ctrl+Shift+M?
It is not customized since I’m on the free plan. I will check that, and also try a fresh install of dynalist app, maybe that could help.
