Move items within single document
Sometimes when I want to move an item, all I see is results from different documents. If I had a separate key I could press to move within a single document, or at least an option to make it so that the move item search only shows results from within the current document, that would make moving items work much more often.
This will only get worse as I use Dynalist more and create more documents. :confused:
Yes! We’re due to make some improvements to move item soon so more relevant (read: stuff closer to that time) will show up at the top.
Looking forward too that
ctrl up down works for me
copy paste for more distanced moves
super surprised you couldnt highlight drag drop
no idea what this ‘search’ thing is about – don’t use it not useful
