"More option" Button not working in mobile mode
Open dynalist in mobile mode, click the “more option” button, say, trying to move the item up or down
A menu appears
No menu appears
Android
Hi Chris, thanks for the bug report! We just noticed as well.
A fix has been made and it’s going to be released asap. Thank you again!
Thanks for your prompt action! :slight_smile:
As of Jan 2, 2017, this bug should be fixed. Let us know if you can confirm it on your end!
Checked. It is fixed! Thank you!! :slight_smile:
On behalf on Erica and Shida, you’re welcome. :+1:
