If you add a link to another node in dynalist with [[ clicking on it in mindmap view only focuses in on said node. It does not take you to this node.
Clicking on the link should take me to the correct node. Also there should ideally be some kind of line indicating that these two nodes are linked.
Just zooms in on node with link.
Win10 chrome
Document with example:
