Jump to a node within a document without zooming on it
Is it possible, when following an internal link, to jump to (select) a node without zooming on it, provided that the node is located in the same document? This kind of internal links is used in Notion, for example:
It would be useful to have such feature in dynalist as well, to speed up navigation within a document.
My use case is presented below:
By clicking on the “concept 1” link (blue) I expect to simply jump to the “concept 1” node (yellow)
However, dynalyst behaves this way:
