Going from Calendar Date to where you set time is easy. But I’m trying to figure out if you can mouse once you are done setting the day.
Just type the date/time string like this:
!(2020-01-22 10:00)
Use 24-hr format for time – so 10:00 PM is
!(2020-01-22 22:00)
Ok great, I see how that works. Thank you!
Hi Tracy,
You can also use !
to invoke the date picker, arrow keys to select date, tab to jump to the time field, and enter to insert the date. That should all be doable with keyboard only as well.
I hope that helps!
