Yes. I just tried it. Took only a couple minutes from start to finish. Checkboxes, highlights, etc are all in markdown format, one .md file per document.
after installing node.js what I have to do…?
- download the whole folder from github
- edit
config.jsonto have your Dynalist Pro API key (I just realized this requires Pro) -
cdinto the folder in terminal. if you aren’t familiar with it, go and ask bard.google.com “how to cd into a folder” - run
npm installin terminal - run
node index.jsin terminal - the finished .md files can be found in a new folder called
test-vaultthat appeared in the folder your downloaded
thanks, I’ll try
after inserting the APY key the config.json edit is done by a text editor?
no need to to be a Pro…account
