Iām Korean user.
After working in an IOS offline environment, I synchronized online, but more than 90% of my data was lost.
Yesterday I wrote in the offline environment in the same way and then synchronized it in the online environment. Successfully synchronized.
All I wrote in the beginning of my offline environment was lost.
Which operating system are you using? iPad(iOS)
Which browser are you using? Mobile app
It is difficult to check the version. I think itās the latest version.
Are you using any third-party scripts for Dynalist, e.g. PowerPack? NO
