Select Text -> In the iOS edit menu alongside with copy/past you will see BIU option.
-> Choose āBoldā or any other option - the text becomes BOLD in while you edit only. After finish of edit text became usual.
I suppose there is an standard iOS bold/italic/underscore conflict with markdown ** and __ signs.
iOS Latest. Safari and mobile app - the same behaviour.
