iOS 13, latest beta
Have a URL/web page open in Safari
Share (up arrow) button, choose âDynalistâ
Popup box appears with âCancel/Postâ and title/thumbnail - all good.
Hit âPostâ
Item would be added to Inbox
If you switch to Dynalist, a box with URL and âAdd/cancelâ is visible - you have to switch to Dynalist and hit that âAddâ to actually add it. If you donât and share something else, you will have lost this data.
iOS 13 beta 13.1
Latest Dynalist - not sure how to tell
