Inline and code blocks are not rendering properly in search
Create an item with either an inline code segment or code block.
For example:
Inline code: `Foobar`
Or:
Inline code block: ```Foobar```
Then search for the text inside of the code segment (Ctrl+F).
When performing regular/flat/global search (Ctrl+F, Ctrl+Enter) the items should render properly if the item is a part of the search term.
The opening single backtick (for inline) or triple backticks (for code block) are also rendered inside of the fixed-width font formatted code block. See below:
Chrome Windows 10.
Found the issue and prepared a patch, will be released next deployment.
This looks to be fixed for code blocks (triple backticks), but not for regular inline code (single backticks).
