Inconsistent shortcuts for OS X on Chrome
  • Go to any note and select it
  • Press: CMD + ALT + N
  • Any notes below will now be in a numbered list
  • Nothing, I need to use Ctrl instead to get a numbered list even though the short cut says to use Cmd
  • OSX 10.11.6
  • Chrome 56
I would prefer to use OSX specific commands. Trying to force the command to use Cmd instead of Ctrl causes it to tell me that “that combination has already been used by ‘Make a numbered list’*”
That’s because Dynalist doesn’t distinguish between Cmd and Ctrl right now (something that we’re looking to fix).
It’s weird that Cmd+Alt+N doesn’t make numbered list though. Does it do anything else, like some build-in system action?
That may be it. I’ll look in to that. If it listens to them the same then that maybe it.
It could also be the other apps on your computer. Some apps listen for global shortcuts to perform certain actions.
