what can i do if i d like to input a comment instead of an item in a document? If i press ENTER, a new item will be added, which is not what i expected. I can make it with my android version. But it doesn’t work in the pc web version. Thanks.
I think what you’re referring to is called notes.
It functions just as you described; adds more info to an item without creating another item.
To use it on the web app or desktop app, just hold shift+enter.
For more handy shortcuts, visit https://help.dynalist.io/article/91-keyboard-shortcut-reference
Great. Thats it. Thanks for your help. Thao
