H1 Headline Format - Intentional?
Especially since I’m avoiding bold and italic in Dynalist because of the markup foobah, I’m using the headlines H1-H3 a lot.
Is it deliberate that when I apply H1 to an entry, the font and spacing gets smaller? I can’t see any justification for this (no pun intended) - at least I would expect the text to stay the same size and just be made bold.
The font should definitely get bigger for H1, compared to a normal item…
Could you give me a screenshot? Thanks so much!
Erica - apologies, I meant to say H3! I think the issue is that the line spacing is reduced when H3 is applied. It just seemed to also make the font smaller.
I’m using Roboto large.
